2003 Isuzu Rodeo Diff Fluid Change Fix
ISUZU
HREGOLI
I have 2003 isuzu rodeo 3.2 l 4x4 I'm trying to change the rear differential fluid but there is no drain plug, is there any other way to drain besdies take of the diff plate?
Aug 26, 2007 at 2:33 AM
SERVICE WRITER
  • 9,123 POSTS
You can buy a tool that sucks fluid out called a fluid suction gun:
https://images.2carpros.com/forum/automotive_pictures/30961_ATD5004_1.jpg
Remove the fill plug and suck out the old oil and refill.
Aug 26, 2007 at 2:43 AM
Suggested Repair
Remove the rear differential fill plug and use a fluid suction gun to extract the old oil, then refill with the correct fluid.
Conversation Summary
The owner of a 2003 Isuzu Rodeo 3.2L 4x4 wants to change the rear differential fluid but found no drain plug and asked if there is a way to drain it without removing the differential cover. The expert recommended a fluid suction gun: remove the fill plug, suck out the old oil, and refill.
