1995 Isuzu Rodeo Clutch Fluid Leak
ISUZU
JESSDAN40
I have a 95 Isuzu Rodeo, 6 cyl, 2wd with a leaky clutch system. I have been refilling the fluid about once a week. This is the third replacement I have had in the past 4 years. Is it so difficult to repair these systems? Is it possible for me to fix the leak without replacing the set? The fluid leaks into the car, under the floor mat, so the leak must be in the connection. If anyone can tell me how to repair this leak without wasting any more money, I would appreciate it! Thanks
Jul 9, 2006 at 5:37 AM
JOUGH626
  • 55 POSTS
I'm not sure what you replaced. But it sounds like your master cylinder is leaking. Check the hose going to it if your sure it's not the cylinder. The clutch system is very basic. I'm sure with a little hunting you can find the leak and stop your problem for good. I hope this helps.
Jul 11, 2006 at 1:25 PM
Suggested Repair
Inspect the clutch master cylinder for leakage and check the hose connected to it. Locate and repair the specific leak rather than replacing the entire clutch hydraulic set again.
Conversation Summary
The owner of a 1995 Isuzu Rodeo reports a recurring clutch-system leak that requires weekly fluid top-offs, with fluid entering the cabin under the floor mat. Components have been replaced three times in four years, and the owner wants to stop the leak without replacing the whole set. The expert says the master cylinder is the likely source and recommends checking its hose if the cylinder itself is not leaking.
