1997 Isuzu Rodeo Clutch replacement
1997 ISUZU
CHAZLINK
  • 6 POSTS
I recently had my clutch go out so I purchased the new clutch and installed it myself. However, at this point, when I push down on the clutch it is VERY difficult to get to the floor - almost as if there is a force pushing back at me after a certain point.
The slave cylinder is indeed moving. I am not sure if the master cylinder was bled correctly since I had that work done by a service technician.
Might you have any suggestions on what this might be?
Any help is greatly appreciated and thank you in advance for all of your valuable time. This is a great site!
Aug 21, 2006 at 2:33 AM
CHAZLINK
  • 6 POSTS
To anyone looking to change the clutch on a 1997 Isuzu Rodeo v6 2WD....this is not the standard push clutch.
It is a pull clutch - so install your components accordingly. That is where I went wrong.
I did not connect the release bearing to the clutch properly.
Tranny to come down again...oh joy....
-Chaz
Aug 22, 2006 at 4:37 AM
