1989 Honda Check Engine Light
HONDA
JED BLAINE
one mile down the road the engine check light came
on. my repairman looked under the hood and under
the drivers seat. without any other diagnostic testing he told
me i needed to replace the distribitor. i drive a 1989
honda lxi with 96,000 miles. does this sound legit?
thanks.......
Aug 10, 2006 at 1:35 PM
VANDRAGON
  • 298 POSTS
if the car runs fine and does not stall, i would say he is full of cow patties. honda programs the computer to turn on the light ever 5,000 to 7,000 miles to remind you of oil change time. on some cars you can hold down the trip counter button while turning the key on(make sure the dash lights up) without starting, then off and on again and starting the engine while still holding the counter button. wate until the beeps and lights all go out along with the service light before releasing the trip counter button.
Aug 12, 2006 at 12:54 AM
TORPEDO1517
i have a 1999 honda civic DX mileage 189683, and the check engine light went on after i ran through a flooded area in low gear to get home during a typhoon, and then now it also feels like it slams into gear when it shifts into 2nd gear, now i've been told that one of the clutches or bad and since i've been reading that the CPU box lets you know that there something wrong could the clutch really be the problem, and if not, i had changed my stock headers and muffler to aftermarket parts and one of the O2 censors aren't connected could that be the problem someone who knows please reply..
Aug 15, 2006 at 5:13 PM
Suggested Repair
If the 1989 Honda runs normally and does not stall, do not replace the distributor based only on the light. The check/service light may be a programmed oil-change reminder every 5,000 to 7,000 miles. Reset it by holding the trip-counter button while cycling the ignition as described, and have proper diagnostics done before replacing parts.
Conversation Summary
The owner of a 1989 Honda LXi with 96,000 miles said the check engine light came on after one mile, and a repairman recommended a distributor without further testing. The expert said that advice is not credible if the car runs fine and does not stall, explaining that Honda may illuminate the light as a service reminder and describing a trip-button reset procedure. A later post about a 1999 Honda Civic DX with a light after driving through floodwater, a harsh 2nd-gear shift, and a disconnected oxygen sensor received no expert reply.
