1988 Honda Accord Acceleration Jerk
HONDA
NASTARR75
I have replaced the spark plugs, wires, distributer cap and rotor. As well as the valve cover gasket and had the timing adjusted.
When I drive my car (1988 Honda Accourd LX, w/ 230,000miles 4cylinder) it spudders when accelerating as if it is trying to shift. When I accelerate the car fells as if it jerking back and fourth. I have no problems with the clutch or shifting in anyway. Up until recently it would only do this when the car warmed up. Now it is doing this when the car is cold as well. Anything you could suggest would be great.
Thank You,
Nick
Feb 23, 2007 at 11:44 AM
  • 75,988 POSTS
[quote:3421b627e3="NAStarr75"]I have replaced the spark plugs, wires, distributer cap and rotor. As well as the valve cover gasket and had the timing adjusted.
Thank You,
Nick[/quote:3421b627e3]
Start with having the fuel pressure check
Feb 24, 2007 at 6:14 AM
Suggested Repair
Have the fuel pressure checked as the next diagnostic step.
Conversation Summary
The owner of a 1988 Honda Accord LX with 230,000 miles reports jerking and sputtering under acceleration, now both cold and warm, after replacing the spark plugs, wires, distributor cap and rotor, and valve cover gasket and having the timing adjusted. Clutch and shifting feel normal. The expert recommends starting with a fuel pressure check.
