1994 Honda Integra Idle Surges
1994 HONDA
BLAIR182
hey everyone. i have a '94 integra which has a swapped B18B1 engine with only 40,000 km's on it. An when i don't drive it for a couple days, then go to start it, the idle goes nuts.. it revs up and down.. what needs to be done? just a trottle adjustment? er what?! i'm not great with engines. the help would be awesome! thanks.
May 8, 2006 at 9:24 PM
BRUCE HUNT
  • 3,754 POSTS
Does the throttle settle down eventually after the engine warms up? Coolant level in the engine is important and no air in the system. Try bleeding the coolant. There are other things that cause the surging as well including the IAC (idle air control) and the air intake sensor. No Check Engine Light?
May 9, 2006 at 4:24 AM
Suggested Repair
Confirm whether the idle settles after warm-up. Check the coolant level and bleed air from the cooling system. Also inspect the idle air control valve and intake air sensor, and note whether a check engine light is present.
Conversation Summary
The owner of a 1994 Honda Integra with a swapped B18B1 engine reports that the idle surges up and down after the car sits for a couple of days and asks whether a throttle adjustment is needed. The expert asks whether it settles once warm, recommends checking the coolant level and bleeding air from the system, and also points to the idle air control valve and intake air sensor while asking about a check engine light.
