1994 Other Honda Models rover 216
1994 HONDA
P0RNSTARSEAN
Engine Mechanical problem
1994 Other Honda Models 4 cyl Manual
ive just finished doin an engine swop on a 216 coupe with the honda engine as mine blew its head.after changing all the electrics i tryed to start it with no luck.the engine turns over but wont start.as i found out there is no spark or fuel being pumped to the injectors thanks to a haynes manual.but ive ran out of ideas any help would be great the honda ive listed has the same engine
Jun 26, 2008 at 8:16 AM
KHLOW2008
  • 41,812 POSTS
Hi p0rnstarsean,
Is there power supply to the distributor?
Did you miss out on the grounding points at the thermostat housing?
Are the connectors at the driverside wheelhouse and firewall properly connected?
Jun 26, 2008 at 8:30 AM
