1993 Honda Rough Idle PCV Valve
1993 HONDA
BIGBOBMAL
  • 12 POSTS
my car is idling rough not dying was told by mechanic it may be pvc valve i took it out cleaned it and blew trough the end of it air came out also you can shake it and it is not stuck do you think it could still be the valve also the hose does not have clamps on them connecting to vavle .
May 16, 2006 at 4:06 PM
LOSONE
  • 1,616 POSTS
You must also clean the orfices inside the engine. Clamps aren't an issuse unles the hoses come off.
May 17, 2006 at 5:46 AM
BIGBOBMAL
  • 12 POSTS
i don't know what orfices are could you explain thanks.
May 18, 2006 at 3:10 PM
LOSONE
  • 1,616 POSTS
The holes inside of the intake manifold.
May 19, 2006 at 1:25 AM
Suggested Repair
Clean the PCV orifices (holes) inside the intake manifold, not only the valve. Hose clamps are not a problem unless the hoses come off.
Conversation Summary
A 1993 Honda idles roughly but does not stall. A mechanic suggested the PCV valve; the owner cleaned it, confirmed air passes through, and found it is not stuck, and also noted the connecting hose has no clamps. The expert said the orifices inside the engine must also be cleaned and explained those are the holes in the intake manifold. Clamps are not an issue unless the hoses come off.
