1992 Honda Civic High Idle Hesitation
MY808MOM
1992 honda civic 4 door 220000 miles. My car hesitates while driving, and when i start it the engine revs(its an automatic) real bad. i was just doing a glance over simple things like the spark plugs, oil, and when i got to the air filter i was surprised to see it was brand new!!! i"ve had the car for almost a year now and not once have i changed it. could there be a leak in my intake system, and could that be causing my car to run sloppy?
Aug 30, 2006 at 8:22 AM
MIKEYBDMAN
  • 623 POSTS
[quote:81c104eb7b="my808mom"]1992 honda civic 4 door 220000 miles. My car hesitates while driving, and when i start it the engine revs(its an automatic) real bad. i was just doing a glance over simple things like the spark plugs, oil, and when i got to the air filter i was surprised to see it was brand new!!! i"ve had the car for almost a year now and not once have i changed it. could there be a leak in my intake system, and could that be causing my car to run sloppy?[/quote:81c104eb7b]
Yes it could. I would look over the air intake ducts and see if it has disconnected. Could be sucking air from other than your filter, and that is not good. If this is the case, your throttle body, along with most sensors are probably dirty and in need of cleaning. This is probably where your poor running condition is coming from.
Aug 30, 2006 at 8:46 AM
Suggested Repair
Inspect the air intake ducts for a disconnection or leak that could let the engine draw unfiltered air. If found, clean the throttle body and related sensors.
Conversation Summary
The owner of a 1992 Honda Civic reports hesitation while driving and high revving at startup. The air filter looks new even though it was not replaced. The expert says an intake leak is possible and recommends checking the intake ducts, then cleaning the throttle body and sensors if unfiltered air has been entering.
