1998 Honda Civic Cold Acceleration Loss
TLCBAE
I HAVE A 1998 HONDA CIVIC DX NON VTEC WITH 180000 MILES. I REPLACED THE TIMING BELT, NEW FUEL FILTER AND AIR FILTER, NEW DISTRIBUTER AND SPARK PLUG AND WIRES AND EACH MORNING IT STARTS UP FINE, BUT WHEN I TAKE OFF, IT BOGGS DOWN FOR A FEW SECONDS THEN PICKS UP, IT DOES THIS UNTIL IT WARMS UP, DO YOU HAVE ANY IDEA WHT IT MIGHT BE, THANKS, THOMAS
Aug 4, 2007 at 2:00 PM
BRUCE HUNT
  • 3,754 POSTS
Check the coolant for air and purge it. The IAC valve could be clogging and in need of cleaning. The EGR valve could need to be cleaned or replaced. Those are a starter, there are other possibles. You've done some other basic ones.
Aug 6, 2007 at 7:14 AM
Suggested Repair
Check the coolant for air and purge it. Clean the IAC valve if it is clogged, and clean or replace the EGR valve. These are starting checks; other causes are still possible.
Conversation Summary
A 1998 Honda Civic DX with 180,000 miles starts fine each morning but bogs for a few seconds on takeoff until it warms up. The owner already replaced the timing belt, fuel filter, air filter, distributor, spark plugs, and wires. The expert suggested purging air from the coolant, cleaning a clogged IAC valve, and cleaning or replacing the EGR valve as initial checks.
