2005 Honda Odyssey Auto Headlight Switch
UNCLEPONTO
I have a 2005 Honda Odyssey EXL; 44500 Miles. Around 2005 Honda started installing DRL/auto on/off headlights on its vehicles as a standard feature but my vehicle must have missed the cut. I have the manual on/off light switch. No auto/on off and no DRL.
My windshield appears to have the photo-sensor installed.
So, is it possible to change out the light switch on the steering column for a switch that will enable the auto on/off headlights? Honda doesn't make a kit for this but could another aftermarket switch be used? If so, would this be a fairly simple exchange? If not, where would be a good place to look to get it done? Mechanic, Audio shop, somewhere else?
Thanks.
Dan
Sep 7, 2007 at 7:32 AM
MERLIN2021
  • 17,250 POSTS
Probably gonna regret any aftermarket headlight switch installation! You will need to get a new Body control module, and because the car was not built for this you won't find the right module! It will be less agravation to buy a new honda!
Sep 7, 2007 at 10:06 AM
UNCLEPONTO
Well, with an ominous reply like that, I'll just have to let me wife turn the lights on and off manually. Perish the thought!
Sep 10, 2007 at 8:55 AM
Suggested Repair
Do not install an aftermarket headlight switch to add auto on/off headlights or DRL. The vehicle was not built with the required body control module, and a compatible module is not available. Keep the manual switch.
Conversation Summary
The owner of a 2005 Honda Odyssey EX-L with a manual headlight switch asked whether an auto on/off DRL switch could be installed, noting that a windshield photo sensor appeared to be present. The expert advised against an aftermarket switch, explaining that a new body control module would be required and the correct module is unavailable because the vehicle was not built for the feature. The owner decided to continue using the manual switch.
