1996 Honda Odyssey ABS Light On
KASIAPOO
I have a 1996 Honda Odyssey with 102K miles. Recently the ABS light started coming on at times. The local Honda service people said that the accumulator and modulator must be replaced at a cost of $1250. I have asked around and none of the independent shops will touch ABS systems.
The brakes work fine but I don't know if my next inspection will pass if the light is on. Any suggestions?
Mar 28, 2006 at 10:56 AM
LOSONE
  • 1,616 POSTS
Most Honda ABS light off/on problems come form dirty sensors on the wheels. They collect metal shavings from brake pads and can be easily cleaned. Find a shop that can read the ABS codes and pinpoint the source of the problem before you spend the $1250.00.
Where have the real mechanics gone!!
Mar 2, 2021 at 1:46 AM
Suggested Repair
Have a shop read the ABS codes before replacing the accumulator and modulator. Clean the wheel speed sensors, which can collect metal shavings from the brake pads and cause intermittent ABS lights.
Conversation Summary
A 1996 Honda Odyssey with 102,000 miles has an intermittent ABS light while the brakes still work normally. A Honda dealer recommended replacing the accumulator and modulator for about $1250, and independent shops declined ABS work. The expert advised reading ABS codes first and cleaning dirty wheel sensors, a common cause of Honda ABS lights, before spending that amount.
