1999 Honda Odyssey Stuck in Park
STACY M
I have a 1999 Honda Odyssey with approximately $75,000 miles on it. Recently, I have had difficulty shifting the car from park into drive. It appears as though it gets stuck. Eventually it will let me shift, but it often takes a few minutes and I usually hear a clicking noise right before it allows me to shift into drive.
Dec 8, 2006 at 5:48 AM
2CARPRO JACK
  • 11,533 POSTS
There is a safety device on the shifter that wont let it come out of park unless the brake is depressed.It sounds like that solenoid or the relay is getting a little sticky or is ready to fail.Try pushing on the brake pedal repeatedly until you hear the click, but i would get it taken care of before it leaves you stranded.
Dec 8, 2006 at 7:26 AM
Suggested Repair
Have the brake shift-interlock solenoid or relay inspected and repaired before it fails completely. Repeatedly pressing the brake pedal until the click is heard may temporarily release the shifter.
Conversation Summary
The owner of a 1999 Honda Odyssey with about 75,000 miles reports difficulty shifting from park into drive. The shifter eventually releases after several minutes, often with a clicking noise. The expert explains that the brake-shift safety interlock may have a sticky or failing solenoid or relay and recommends repairing it before the vehicle becomes stranded.
