2004 Honda Odyssey Parking slipping out of gear
2004 HONDA ODYSSEY
HONDA04MN
2004 Honda Odyssey 45,000 miles
After I park my car and put the car into park, and turn it off. When I go to restart the car, it starts just fine, but then the "P" on the dash is not lit up, and I cannot shift it out of park. If I rock the car enough, I can get it to go into park, then I can shift into drive. If I put on the e-brake before I put the car into park, I do not have this problem.
Dec 9, 2009 at 12:30 AM
KHLOW2008
  • 41,814 POSTS
Hi honda04mn,
The Park Neutral Position switch seems to be out of adjustment and you need to get it adjusted. When the P light is not indicating, you would not be able to get it out of park unless you use the emergency slot.
Dec 9, 2009 at 7:40 PM
