D light flashing
2003 HONDA ODYSSEY
127,000 MILES • 3.5L • 2WD • AUTOMATIC
JOHNNY35692003
It will drive fine until the engine is warm, then the D light flashes along with the maintenance, TCS, engine. When this happens, the transmission shifts hard with clunks. If I press the reset button on where the speed gauge are, the lights go out and it drives fine again. Any help? Just changed the fluid and transmission filter.
Aug 12, 2018 at 1:20 PM
  • 55,433 POSTS
This is a common issue when the turbine sensor goes out the transmission will shift funny. We can scan the PCM to confirm the issue which can be done by following the guide below.
Here is a video of a sensor getting installed on a similar Honda:
https://youtu.be/KRTJYOXuON8
Check out the diagrams (below). Please let us know what you find.
Cheers, Ken
Aug 14, 2018 at 4:41 AM
