2001 Honda Odyssey Rear Brake Screech
IQBAL71
I have a Honda Odyssey 2001, 83000 miles and V6 engine. I bought from a private party last year. I heard a loud screeching sound coming from the back when i pressed the brakes. It has been going on for the last 2/3 days. What is the problem? or what needs to be fixed? :o
Mar 14, 2007 at 2:46 AM
BRUCE HUNT
  • 3,754 POSTS
You need to pull this in to the garage and have the brakes looked at. You might have gone down to the warning indicator on the brakes and if they get that loud you may be through the pad and into the metal of the pad, thus harming the rotors.
Mar 1, 2021 at 5:45 AM
Suggested Repair
Have the rear brakes inspected. Loud screeching may mean the pads are worn to the wear indicator or metal backing, which can damage the rotors; replace the pads and resurface or replace the rotors as needed.
Conversation Summary
The owner of a 2001 Honda Odyssey with 83,000 miles reported a loud screeching noise from the rear when braking for two to three days. The expert advised a brake inspection, noting the pads may be worn through to the warning indicator or metal and could be damaging the rotors.
