1997 Honda Odyssey check light on
IULIU
Engine problem
1997 Honda Odyssey 4 cyl Front Wheel Drive 135000 miles
Dear Friends,
The car start running in 3 cylinders and the check light went on. I foung a bad spark plug and I replaced it. It works OK now, but the checkk light is still on. It is another problem with the engine, or I have to reset the light somehow?
Thanks,
Iuliu Blaga
Jan 22, 2008 at 2:54 AM
MERLIN2021
  • 17,250 POSTS
You can only reset the light with the right code scanner...just drive until it resets...it will do it once the required drive cycles have been driven, that is if the problem is resolved!
Jan 22, 2008 at 2:59 AM
IULIU
[quote:4465a1bbce="merlin2021"]You can only reset the light with the right code scanner...just drive until it resets...it will do it once the required drive cycles have been driven, that is if the problem is resolved![/quote:4465a1bbce]
Thanks a lot,
Iuliu
Jan 22, 2008 at 3:45 AM
