car wont shift/start
MARRATHON6
94 honda del sol, manual, 4 cyl.... i was recently given this car, it has 120,000 miles on it originally, but it also has a new engine with about 600 miles on it. There are two major problems that both occurred on the same day: First, the car would not shift into gear when i started it. I turned the car off, and it would shift. I started the car while in first (foot on clutch) and it drove ok. Later that day, my battery died. I let it charge after i jumped before trying to drive it. It grinded really bad when i tried to shift into reverse. When it was finally in reverse, the car stalled out when i tried to drive it. I went to start it and the battery had already died. I pushed it out in neutral, jumped it, and when i drove it home it was reluctant to switch gears. Now that its home, it wont hold a charge, and it wont shift gears when the car is on. Is this a clutch problem, a battery problem, or both?
Jul 27, 2007 at 2:15 PM
HONDATECH74
  • 34 POSTS
[quote:f859071540="marrathon6"]94 honda del sol, manual, 4 cyl.... i was recently given this car, it has 120,000 miles on it originally, but it also has a new engine with about 600 miles on it. There are two major problems that both occurred on the same day: First, the car would not shift into gear when i started it. I turned the car off, and it would shift. I started the car while in first (foot on clutch) and it drove ok. Later that day, my battery died. I let it charge after i jumped before trying to drive it. It grinded really bad when i tried to shift into reverse. When it was finally in reverse, the car stalled out when i tried to drive it. I went to start it and the battery had already died. I pushed it out in neutral, jumped it, and when i drove it home it was reluctant to switch gears. Now that its home, it wont hold a charge, and it wont shift gears when the car is on. Is this a clutch problem, a battery problem, or both?[/quote:f859071540]both.
Feb 27, 2009 at 12:06 PM
