1988 Honda CRX No Crank Buzzing
R X A X I X N
Honda, CRX, 1988, 148,695 mi., V4. Ever since winter started my car was having trouble starting: It would turn over but you had to hold it for at least 30 seconds to get it started. Sometimes if you let go of the soon it would just shut off. Then a couple days later it wouldn't even turn over at all. Makes sort of a faint buzzing sound when you try to start it. Checked the battery and terminals everything checks out. Please can you help me?
Mar 11, 2007 at 12:33 PM
  • 75,988 POSTS
Load test the battery to check its actual condition.If it cannot maintain 9.6volts in 10secs while loaded get rid of it.
Double check all connections involved from the batt to the starter
Mar 11, 2007 at 9:07 PM
R X A X I X N
The battery is good and everything connecting to it. I just found something interesting when you turn ignition theres a lilttle cyclinder object at the far back near the windshield with 4 VL on it and you can feel it click when trying to start any suggestions?
Mar 12, 2007 at 2:22 PM
  • 75,988 POSTS
[quote:683f1ea304="R x A x I x N"]The battery is good and everything connecting to it. I just found something interesting when you turn ignition theres a lilttle cyclinder object at the far back near the windshield with 4 VL on it and you can feel it click when trying to start any suggestions?[/quote:683f1ea304]
Could be a starter relay-investigate what it is
Mar 12, 2007 at 2:28 PM
BOARDERBW
  • 19 POSTS
hey rxaxixn
Before you try to start your car, turn on your lights. Try to start it and if your lights dim, that means the starter soleniod is ok , but the starter may still be the problem. If they dont, either there is no power getting to your starter or the soleniod is shot and it needs to be replaced.
Hope I helped.
Mar 14, 2007 at 7:00 PM
TINY CAR GRAVEYARD
I have what may be a similar problem with my 86 crx. when i am starting it in high moisture type weather i have to crank on it for like 30 seconds til it starts. i assume thats because of a bad seal that lets the moisture in. not sure where.
Mar 16, 2007 at 11:03 AM
Suggested Repair
Load-test the battery and verify all connections from the battery to the starter. Identify the clicking cylinder near the windshield, which may be the starter relay. Use a headlight dim test: if the lights dim while cranking, the solenoid is likely working and the starter may be at fault; if they do not dim, check for no power to the starter or a failed solenoid.
Conversation Summary
The owner of a 1988 Honda CRX reported hard winter starting that progressed to a no-crank condition with a faint buzzing sound. The battery and terminals checked out, and a small cylinder near the windshield clicked when the key was turned. Experts recommended a battery load test, inspection of starter-circuit connections, investigation of a possible starter relay, and a headlight dim test to distinguish a bad solenoid from a starter problem.
