1986 Honda CRX car will not start
RAFAEL21503
  • 1986 HONDA CRX
  • 4 CYL
  • MANUAL
  • 240,000 MILES
I have a 1986 Honda CRX with 240,000 miles. Everything was working fine until one night I went to turn it on and it would not. It seems like it wants to turn on but doesn't. I turned the key to turn it on and pressed the accelerator but it would not. Since my gas tank was on empty I figured it was the gas so I went and got some gas to put in it but still nothing. At this point I replaced the gas pump with a new one, checked the ignition, the spark plugs & nothing. Fuel does go into the carburator but don't know what else could be wrong. Please help
Wednesday, April 14th, 2010 AT 8:33 PM
Check for spark
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark?
Thursday, April 15th, 2010 AT 2:45 AM
RAFAEL21503
Already checked for a spark and it does spark?
Sunday, April 25th, 2010 AT 5:15 PM
Check the fuel pressure if its within specs and also for injection pulses
Sunday, April 25th, 2010 AT 5:55 PM
