91 Honda Crx, the timing belt went out while I was driving it. What damage can I expect to repair? Will it be easier just to replace the engine.
Jun 29, 2006 at 11:41 AM
Expect cylinder-head damage from the failed timing belt. Shop for a new or good used head, and compare that with engine replacement, since a Honda rebuild is often considered less desirable than a replacement engine.
The owner of a 1991 Honda CRX says the timing belt failed while driving and asks what damage to expect and whether replacing the engine would be easier. The expert says a Honda rebuild is often not as good as a new engine and that the likely repair is a new or good used cylinder head.
