1987 Honda CRX wont fire
200,000 MILES • 4 CYL • FWD • MANUAL
ISIAHA
hi i have a 1987 crx si the fuel pressure reg went out so i replaced it but it still wont fire i have spark and fuel and it cranks but just wont fire and is there a way to check codes on this car??? thanks
Oct 10, 2008 at 10:34 AM
  • 75,988 POSTS
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time/broken or jumped timing belt/chain
_________________
Oct 10, 2008 at 10:44 AM
