1997 Honda CR-V Differential Failure
JAIDEE2295
I am about to purchase a 1997 with only 98,000 but the sales guy was honest and up front saying that the differential is shot and needs to be replaced. Claims that this is a normal thing that occurs with this make and model, and once changed everything will be fine. I need to know if this is true since I have never owned a Honda or know anyone that does. Feedback would be greatly appreciated!!
Sep 17, 2007 at 6:17 AM
LOSTINMARS
  • 222 POSTS
yes its not an uncommon problem on a crv that wasn't cared for properly. makes me wonder about the rest of the vehicle. the rear diff fluid on these needs to be changed often (every 15k imo) and with the correct honda fluid.
i would try changing the fluid 1st.
Sep 21, 2007 at 2:15 PM
Suggested Repair
Try changing the rear differential fluid first using the correct Honda fluid. On these CR-Vs the fluid should be changed often, about every 15,000 miles, especially if maintenance was neglected.
Conversation Summary
A buyer considering a 1997 Honda CR-V was told the differential is failed and must be replaced, and that this is normal for the model. The expert said rear differential problems are not uncommon when a CR-V was not properly maintained, and recommended trying a fluid change with the correct Honda fluid first.
