1998 Honda CR-V Soft Clutch Pedal
JVITALE3
I have a 1998 Honda CRV, all wheel drive, stick shift, 4 cylinder, with 120,000 miles on it. I recently had the timing belt changed and the brakes repaired. When I press in the clutch, it now feels 'soft' and I have to push it all the way down to the floor before it seems to engage. It will also stick half way up sometimes when I take my foot off.
Approximately how much would it cost to fix the problem, and is this a worthwhile amount of money to invest in a car this old, given that I just spent $1500.00 for the timing belt.
Aug 2, 2007 at 4:39 AM
BRUCE HUNT
  • 3,754 POSTS
Sounds as though you are seeing the failure of the clutch system. This could just be the master cylinder on the clutch. So, considering the amount you have recently spent on the vehicle, it appears to be worth it to get this fixed. Just part of normal wear and tear on the car.
Aug 2, 2007 at 4:53 AM
Suggested Repair
Have the clutch hydraulic system inspected, starting with the clutch master cylinder, which may be failing and causing the soft, low-engaging, sticking pedal. Repair is reasonable given recent maintenance.
Conversation Summary
The owner of a 1998 Honda CR-V with 120,000 miles reports a soft clutch pedal that must be pushed to the floor to engage and sometimes sticks halfway up, after recent timing belt and brake work. They ask about repair cost and whether it is worth fixing after spending $1,500. Expert Bruce Hunt says this indicates clutch system failure, possibly the clutch master cylinder, and that repair is worthwhile as normal wear.
