1999 Honda CR-V Washer Nozzle Clogs
Suggested Repair
Disconnect the washer hose at the clogged nozzle and blow it out backward so debris is not pushed farther into the line. If the connection is hard to reach, cut the hose and install a small plastic union, then blow from the nozzle. If both nozzles clog, siphon the washer reservoir, including sediment at the bottom, run the disconnected line empty to flush debris, then refill and reassemble.
Conversation Summary
The owner of a 1999 Honda CR-V said one front windshield washer nozzle repeatedly clogs and only trickles fluid, and asked how to repair it without a mechanic. The expert advised against only using a pin, which can push debris back into the line. They recommended disconnecting and blowing out the hose, using a plastic hose union if needed, and flushing the reservoir and lines if both nozzles clog.
