well my problem started a few weeks ago.when ever i start the car and drive to work it's fine but once a few minutes gose by and the motor start to heat up,it will start to make a rattling sound when i apply gas.even sometime when i stop at a redlight or something you can still hear it .The sound coming from the front driver side fender.yesterday i took the car to a shop the guy check it out,told me that i didn't have any power steering fluid.he told me all i had to do to fix this problem was to go buy some power steering fluid and it'll stop the noise.so i did but it still rattles. Help me anyone
1990 Honda Integra Heat Rattle
HONDA
i have a 1990 integra Ls with a Japan honda 1.6L vtec motor swap. motor has 57,000 miles.
Mar 11, 2007 at 6:54 AM
Do yourself a favor and check the harmonic balancer to see if it is loose.
Mar 12, 2007 at 2:23 AM
i checked that already it's not loose.
can a bad belt cause this problem
Mar 12, 2007 at 3:17 PM
Now you are in to finding wihich belt driven device has a bearing going out.
Mar 13, 2007 at 4:39 AM
how do i do that
Mar 13, 2007 at 9:04 AM
Well, you could take it in to the shop or you can take the belts off and turn the pulleys of the alternator, a/c, power steering or idler pulley and see how smoothly they turn. I would venture that one of them will come up rough. While the belts are off, check them for cracking and wear.
Mar 13, 2007 at 9:36 AM
how much do u thing is gonna cost me for a shop to check to see where's the problem is and fixing it
Mar 13, 2007 at 11:31 AM
Well it shouldn't cost too much to remove and check the systems. Once the one is located, then the cost goes up as they remove it, replace it and re-install. The parts will vary in complexity of work and cost.
I would take it to a shop, have them listen to the sound and confirm my suspicions. They will probably do that for you and give you an estimate.
Mar 14, 2007 at 4:44 AM
Suggested Repair
With the harmonic balancer already confirmed tight and power steering fluid not fixing the noise, remove the belts and spin the alternator, A/C, power steering, and idler pulleys by hand to find a rough bearing. Inspect the belts for cracking or wear, then have a shop listen and confirm before replacing the failed component.
Conversation Summary
A 1990 Honda Integra LS with a Japanese 1.6L VTEC swap rattles from the front driver-side fender once warm, including at idle. Adding power steering fluid did not stop it, and the harmonic balancer was not loose. The expert advised isolating a failing belt-driven bearing by removing the belts and turning the accessory pulleys, checking belt condition, and having a shop confirm the source and estimate the repair.
