Compression check was done and checked out by Honda specs. All sensors, tps, map, crannk position sensor, intake air temp sensor, crank flucuation sensor, cylinder positioning sensor, top dead center positioning sensor, evap salonoied, fuel pressure regulator, fuel pressure, ignition coil, p.C.M, ignition control module, battery voltage, neutral safety switch, injection trigger signal, injectors c.P.U, fuses and relays, timing belt and relay, was all checked with a multi meter and noid lights. Everything checked out within hondas specks. Check ingine light comes on and goes off when ignition is turned on, no trouble codes in computer. Had it started a few times when u would hit the gas the engine would die, and now the engine will not start at all.
Sunday, October 4th, 2009 AT 4:33 PM
