1998 Honda CRV 4 cyl Two Wheel Drive Manual
I have a 97 Honda Civic that has had an engine swap. The motor in the car is from a 98 Honda CRV. I have recently been having issues with the battery dying. We replaced the alternator and got a new battery but it was still happening. Then the battery cap came off and spewed battery acid all over the motor. Does the alternator have a built in voltage regulator? What else would be causing the battery to over charge?
Also I am having some ECU issues. When getting a ECU what specific vehicle info is required? For example does it matter if it is for an auto or manual, 4WD or 2WD.
Tuesday, March 9th, 2010 AT 10:51 AM
