Crank, no start
220,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
GOMEZJB714
Previous owner was in accident leaving radiator support bent in. Had tied support beam to tree and was reversing to align. Gave some revs. It straightened but not enough So after just a bit more juice the car shut off.
Now only cranks but no turn over.
New battery
New spark plugs
New distributor
Thinking crankshaft position sensor,fuel pump or compression.
The scenario of reversing while tied is the focal point why it shut off and trying to figure what specifically is damaged due to shut off during.
Besides just engine failure
Cranks sounds like a skip almost.
May 18, 2021 at 12:19 AM
  • 110,244 POSTS
The crank no-start condition can be caused by a couple of things. In most cases, it is either related to a fuel issue or an ignition issue. You could try to see if it starts using starting fluid for a few seconds and then stalls. That would indicate a fuel pressure issue. If it doesn't change anything, then it is likely related to ignition spark.
First, take a look through this link. It discusses the most common causes of a crank no start.
Also, here are two additional links. One is for testing ignition spark and the other for testing fuel pressure.
Start by checking those things and let me know the results. Also, if it's possible for you to record it cranking and upload it for me to hear, it may be helpful. The skip you are referring to has me concerned. It could be a timing issue.
Take care and I'll watch for your reply.
May 18, 2021 at 12:42 PM
