1994 Honda Civic VTEC Engine Swap
CHRIS24
  • 10 POSTS
quick question i have a 94 honda civic dx 1.5 lieter sohc . im going to buy a sohc 16 valve v-tech engine. i know i need to get the computer chip changed. would i also need to change the transmission as well . my cars a stick. and would i need to change out the clutch ?
Jul 30, 2007 at 6:10 PM
BRUCE HUNT
  • 3,754 POSTS
Generally I would think it should work and the clutch should be fine but the best advice on this comes from the auto salvage people. They know the swap and replace game. You never mentioned the year of the motor. That might be helpful.
Jul 31, 2007 at 2:04 AM
GASSAVER
  • 5 POSTS
If you switch to a D16z6 Vtec you can still use your DX tranny and it will be fine. But it is recommended to swap both the engine and tranny from the EX so that you can have a short gear ratio compared to the DX which has a long gear box. And since your going to be building the nused engine in you might as well replace the clutch And if you can look for a p28 ecu it is the ECU from a EX will perform better then getting one chipped. Never can trust them since everyone and their grandmother is doing it. This swap is very common and can be found by doing a google search. Or you can go to D-series.org.
Aug 2, 2007 at 6:25 AM
Suggested Repair
A D16Z6 VTEC can generally use the existing DX manual transmission and clutch, but swapping the EX engine and transmission together is preferred for the shorter gearing. Replace the clutch while the engine is out, and use a P28 EX ECU rather than a chipped computer. Confirm donor-engine year and compatibility with a salvage yard familiar with this common swap.
Conversation Summary
The owner of a 1994 Honda Civic DX with a 1.5L SOHC engine and manual transmission asked whether a SOHC 16-valve VTEC swap would require a different transmission and clutch in addition to an ECU change. One reply said the swap should generally work and the clutch should be fine, while recommending salvage-yard advice and the donor engine year. Another reply said a D16Z6 can use the DX transmission, but pairing the EX engine and transmission is better for shorter gearing, the clutch should be replaced during the install, and a P28 EX ECU is preferable to a chipped ECU.
