I 'am in the middle of changing the axle assembly in a 1998 Honda Civic. LX. How does the assembly come loose from the transmission?
Nov 23, 2006 at 2:55 PM
Insert a large flat screwdriver between the axle shaft and the transmission and twist gently to pop the retaining ring out of its groove. Drain the transmission fluid first to avoid a mess. A pry bar or soft taps through a block of wood can also free the axle; do not strike the axle directly with a hammer.
The owner of a 1998 Honda Civic LX asked how to release the axle assembly from the transmission. Replies explain that a round retaining tab seats in a groove and can be popped free with a screwdriver twist, pry bar, or soft mallet on wood. The expert recommends a large flat screwdriver and draining the transmission first.
