1991 Honda Civic No Spark When Cranking
DARRELLK
Honda Civic 1991 1.5L 200K miles, Hatchback
Seems to start ok when there are max. Amps available during start. When it starts it runs very well and never dies. When it won't start it cranks very well with no spark at the plugs..
Question
What is stopping my voltage form reaching the plugs? thanks Darrell
Sep 11, 2007 at 11:08 AM
BMRFIXIT
  • 19,053 POSTS
I will check to see if i have b+ on one side of the coil you can use a simple test light conect one end of the test light to a ground and check the coil wires if ok switch the test light and conect one side to b+ and check the coil wires one of them should blink as you try to start if it dont you need a distrbuter if it does and no spark you need a coil
Good luck
Sep 11, 2007 at 12:48 PM
Suggested Repair
Use a test light to confirm battery voltage at the ignition coil and check whether a coil wire pulses while cranking. If there is no pulse, replace the distributor; if it pulses but there is still no spark, replace the coil.
Conversation Summary
The owner of a 1991 Honda Civic says it cranks strongly but sometimes has no spark and will not start, although it runs well once started. The expert advises checking coil power and the cranking pulse signal: no pulse points to the distributor, while a pulse with no spark points to the coil.
