1997 Honda Civic Stalls When Stopping
RICHMAUR
I own a 1997 Dx Honda Civic, s 5 speed tandard transmission, 4ltr engine ,121,000 miles on the car/ When I am making a stop the car will sometimes stall. This occurs sometimes when I keep the clutch in and put in neutral and sometimes when I roll to a stop and keep the car in gear, This does not always happen
Jun 21, 2007 at 7:03 AM
BRUCE HUNT
  • 3,754 POSTS
At other times when a idle is the car running smooth or a little rough? Does the engine speed when sitting and idling run fast then slow then fast etc? Finding this could be a challenge but we can try.
Jun 21, 2007 at 9:54 AM
RICHMAUR
At idle the car sometimes runs a little rough but not really noticable and not slow and then fast
Jun 21, 2007 at 12:33 PM
BRUCE HUNT
  • 3,754 POSTS
Locate the EGR valve on the car and remove it. Clean it and replace but look for defects. It is supposed to seal and open. Check for obstructions to that process.
Jun 22, 2007 at 2:14 AM
RICHMAUR
Thanks I will give this a try and let you know how it works out
Jun 22, 2007 at 9:48 AM
RICHMAUR
I took the car to Jack Williams. They told me that this particular model did not have an EGR valve. They did a scan and advised me that two oxygen sensors needed to be replaced at a cost of over $500. I do not know if this will even fix the problem but I can live with the occasional stalls rather than shelling out this kind of money
Jun 25, 2007 at 8:01 AM
BRUCE HUNT
  • 3,754 POSTS
First of all I can assure you there is an EGR, at least the repair manuals show and I have one on the car I own with the same engine. Now, the O2 sensors. They are so simple to replace. One is a little tougher that the other but you could replace them one at a time. I would start with the upper one which the easiest and is located above the cat converter on the exhaust manifold. Go online and search for a Honda O2 and you can hunt down the O2. Stick with an OEM that has the connection and does not require you to use the old connection. Do not get a universal one. About $60 to $70 each. You can do it. If you have the replacement in hand, take off the electrical connection and then cut the wires above the O2 leaving about 2 inches of wire and cutting with an angle. Put on a socket to remove the old O2 and install the new one using an open end wrench to tighten the new one in to the exhaust manifold. Connect the connector and you have it. Pretty much the same process for the lower one too. I cut the wires above because it still allows the sensor to be re-used in the future for some unknown reason. The angle cut allows you to easily tell which wire connect to which on the O2.
Don't be afraid to try it yourself and save a lot of $$.
Jun 25, 2007 at 8:49 AM
Suggested Repair
Inspect and clean the EGR valve if equipped, confirming that it seals and opens without obstruction. If oxygen sensors are recommended, replace them one at a time with OEM sensors that include the connector, starting with the easier upstream sensor above the catalytic converter.
Conversation Summary
A 1997 Honda Civic with a manual transmission occasionally stalls while stopping, either in neutral with the clutch depressed or while remaining in gear. Idle is sometimes slightly rough but does not surge. An expert suggested removing, cleaning, and inspecting the EGR valve. A shop said this model had no EGR valve and recommended replacing two oxygen sensors for over $500. The expert maintained that an EGR valve should be present and advised replacing the sensors individually with OEM units, beginning with the easier upstream sensor, to avoid the shop cost.
