1997 Honda Civic Stalls When Stopping
Don't be afraid to try it yourself and save a lot of $$.
Suggested Repair
Inspect and clean the EGR valve if equipped, confirming that it seals and opens without obstruction. If oxygen sensors are recommended, replace them one at a time with OEM sensors that include the connector, starting with the easier upstream sensor above the catalytic converter.
Conversation Summary
A 1997 Honda Civic with a manual transmission occasionally stalls while stopping, either in neutral with the clutch depressed or while remaining in gear. Idle is sometimes slightly rough but does not surge. An expert suggested removing, cleaning, and inspecting the EGR valve. A shop said this model had no EGR valve and recommended replacing two oxygen sensors for over $500. The expert maintained that an EGR valve should be present and advised replacing the sensors individually with OEM units, beginning with the easier upstream sensor, to avoid the shop cost.
