Squeaky Clutch Pedal
VINBRIN
1990 Honda Civic Wagon 1.5L, 147,000 miles
The c;utch pedal squeaks when pedal is pressed down or released. Sound is coming from inside the car just above clutch pedal. Clutch job done not to long ago.
Nov 16, 2007 at 3:37 PM
  • 31,937 POSTS
Hi there,
The clutch pedal pivots on a plastic bush, this bush may be worn or very dry. The quick fix is to spray a little lubricant up into the pedal pivot, work the pedal a few times so the lubricant can get in. this should fix the problem in the short term, I am unsure as to how difficult it is to replace the bush on this car, but on similar cars it is not a huge job. Best to get a quote first if you feel your not able to attempt it your self.
Mark (mhpautos)
Nov 16, 2007 at 6:36 PM
ROY BYBEE
common,tell how to fix a97chevrolet camaro sqeeky clutch peddal every time I step down on it?????
May 18, 2012 at 2:41 PM
ROY BYBEE
OK 97 chevrolet camaro the clutch makes a whiney sound every time step down on clutch when I am driving it won"t go in gear,what do I do?
May 18, 2012 at 2:49 PM
