1998 Honda Civic Rattle When Accelerating
DAVECELATA
1998 Honda Civic LX 125,000. For about 2,000 miles an irregular rattling can be heard from the engine. It is pretty bad when starting the car, settles down while idling, but gets bad again when accelerating. The problem seems to be limiting the rate of acceleration...the car doesn't have the power it once had.
Apr 17, 2007 at 3:15 PM
BRUCE HUNT
  • 3,754 POSTS
The rattle and the power loss could be entirely separate issues. Please look at the exhaust system very closely and check the heat shields that are connected to the exhaust system. There are a few of them. They sometimes get loose and rattle. Then you can answer whether or not the car has been overheating or has overheated.
Apr 21, 2007 at 2:58 PM
Suggested Repair
Inspect the exhaust system and its heat shields for looseness that could cause the rattle. Also determine whether the engine has overheated, since the power loss may be a separate issue.
Conversation Summary
A 1998 Honda Civic LX with 125,000 miles has rattled irregularly for about 2,000 miles. The noise is worst at startup, settles at idle, and returns during acceleration, while the car also feels underpowered. The expert says the rattle and power loss may be unrelated and recommends closely checking the exhaust heat shields, then noting whether the engine has overheated.
