What is the easiest way to flush and clean the radiator reserve tank of a 2001 honda civic DX without actually removing it?
Jun 2, 2007 at 8:00 AM
MIKE H R
MEMBER
pinch the return hose going to the radiator, remove any existing anti freeze. using a light detergent clean out the tank. sometime you can get most of the junk out with just flushing it but for heaverier spots you can use a old toothbrush or a brush with a long handle that fits in the tank easily. once the tank is cleaned flush with clean water to remove any soap. flush it out well. then refill with anti freeze
