1998 Honda Civic Radiator Replacement
GHOSTDRGN
i have a 98 honda civic coupe,dx,1.6l,non vtec...im replacing the stock radiator with an all aluminum rad.. what is the proper way to do it? what is the proper way to refill coolant once everything is put back together? i have heard of bleeding the system,how do you do that?
Jun 30, 2007 at 8:51 AM
BRUCE HUNT
  • 3,754 POSTS
Pull out the old one and reverse the process in putting in the new one. If the one you are taking out had a transmission cooler on it so should the new one. You will need to add Honda tranny fluid to the tranny. Fill the radiator full and fill the overflow to the max level. Start and run the engine until it gets to normal temp. Then on the upper hose near the head you will find the bleeder. Slowly open it and let the steam and air out until it is coolant coming out. Close and drive the car then recheck the coolant level and the bleeder.
Jul 2, 2007 at 1:11 AM
Suggested Repair
Remove the old radiator and install the aluminum unit in reverse order. If the original radiator has a transmission cooler, the replacement must have one too, and Honda transmission fluid should be added. Fill the radiator and the overflow tank to the max line, run the engine to normal temperature, then slowly open the bleeder on the upper hose near the head until coolant comes out. Close it, drive the car, and recheck the coolant level and bleeder.
Conversation Summary
The owner of a 1998 Honda Civic coupe DX 1.6L non-VTEC asked how to replace the stock radiator with an all-aluminum unit and how to refill and bleed the cooling system. The expert said to reverse the removal process, match any transmission cooler and add Honda transmission fluid, fill the radiator and overflow, warm the engine, and bleed air at the upper-hose bleeder until coolant flows, then recheck after driving.
