Honda Civic Overheating on Highway
SHEILATOBIN
My Honda Civic EX temp gauage went almost red. The shop first said the fan but then replaced the thermostat. The car is fine on local streets but runs hot 3/4 to almost in the red on highways. I see no coolant leaks. Could the radiator still need to be repaired? The shop says the fan is fine. They put a thermometer by the engine and radiator to support their recommendation. It runs about 180-200 by the engine and anywhere from 100-200 by the different areas of the radiator.
Jul 10, 2007 at 11:53 AM
BRUCE HUNT
  • 3,754 POSTS
I would venture that there is a leak in the system. It lets in air and disrupts the cooling system. You can have it pressure checked. Not all leaks let out fluid, some like at the top of the radiator let in air.
Jul 11, 2007 at 3:18 AM
Suggested Repair
Pressure-check the cooling system for a leak that admits air, including the top of the radiator, even if no coolant is visibly leaking.
Conversation Summary
A Honda Civic EX overheated nearly to red. The shop first suspected the fan, then replaced the thermostat. The car stays cool on local streets but runs hot on the highway, with no visible coolant leaks. The shop reported the fan was fine and measured about 180-200 near the engine and 100-200 at different radiator areas. The expert suggested an air-admitting leak may be disrupting cooling and recommended a pressure check.
