1996 Honda Civic Parking Lights Out
DIRTY_DEEEE
i have a 96 honda civic hx... the problem is my parking lights does'nt lit up both front and rear, but if i turn the signal lights on or the hazard on it works...it lit's up...it blink's both front and rear... i check the fuses under dash i change some new fuses for turn signal and starter signal but stil it does'nt work for the parking ligths... please help me with this thank you...
Apr 25, 2006 at 12:28 PM
BRUCE HUNT
  • 3,754 POSTS
This sounds like you have a fuse #32 that is out or you are losing power somewhere here is a guide and the running light wiring diagrams so we can run some simple tests.
There are two different fuse panels because this is a split year here are both.
Check out the diagrams (Below)
Please let us know what you find.
Cheers
Apr 26, 2006 at 7:30 AM
FLIPST4R
I had the same problem on my car, thanks to this guide my lights work again I replaced the fuse! all fixed.
May 11, 2006 at 4:40 PM
Suggested Repair
Check fuse #32 for the parking/running lights and replace it if blown. If the fuse is good, test for lost power using the running-light wiring diagrams.
Conversation Summary
The owner of a 1996 Honda Civic HX reported that the front and rear parking lights would not light, while the turn signals and hazards still blinked. The expert suggested a blown fuse #32 or a power loss and provided fuse-checking guidance and running-light diagrams. A later commenter said replacing the fuse restored the lights.
