1998 Honda Civic Overheating
ED86
I have a 98' Honda Civic EX, 1.5 engine, 173k miles. I replaced thermostat, hoses, radiator & distributor caps, & new radiator. Still overheating, bubbling out of reservoir & smoking. HELP!!
Apr 6, 2007 at 11:12 AM
JOUGH626
  • 55 POSTS
Make sure your relays and fuses feeding power to the fan(s) are in good working order. Swap out questionable relays for known good ones. Replace temp switch/sensor with a known good one. Ensure water pump is in good working condition.
Apr 7, 2007 at 4:42 PM
  • 75,988 POSTS
[quote:005dbbdddd="ed86"]I have a 98' Honda Civic EX, 1.5 engine, 173k miles. I replaced thermostat, hoses, radiator & distributor caps, & new radiator. Still overheating, bubbling out of reservoir & smoking. HELP!![/quote:005dbbdddd]
Pressure test the Cap- Fan coming On or what?
Check the oil dipstick-is it milkshake looking or oil in the coolant. Lets not think! headgasket yet!!!!
Apr 8, 2007 at 1:24 AM
Suggested Repair
Check cooling-fan relays, fuses, and the temperature sensor, and confirm the fans come on. Pressure-test the radiator cap, verify the water pump, and inspect the oil and coolant for mixing before assuming a head-gasket failure.
Conversation Summary
The owner of a 1998 Honda Civic EX reports continued overheating, reservoir bubbling, and smoking after replacing the thermostat, hoses, radiator, and distributor cap. Experts recommend checking fan power, the temperature sensor, radiator cap, and water pump, and looking for oil-coolant contamination before concluding a head-gasket problem.
