1994 Honda Civic Overheating After Crash
MIKEGETSGUAP
1994 Honda Civic EX-Coupe with a 1.6L VTec engine 150,000 recently was in a front end crash and replace the whole front end of course new radiator...... after crash bubbling has been going on in coolant tank while speeding and over-heats after about 5 or 6 minutes on the high way also steam has been coming out of coolant tank...fan turns on but only seems to work if im not drivin at high way speeds (i tried the trick of turning the heater on while driving) this only works for a few minutes but if i was to speed the car would surely over heat i took it too 2 places one place said it was most likely the waterpump the other place said it was most likely air bubbles and a bad fan or fan relay or something as simple as a fuse...i jus need some insight because im tight on money college student living pay check to paycheck thanks....
Dec 31, 2006 at 2:22 AM
BRUCE HUNT
  • 3,754 POSTS
Please check closely in to the bubbling in the tank. First, when the engine is very warm, slowly crack open a bleeder valve on the cooling system to let out the air. Completely void the cooling system of air. Do this when the car is running.
Then watch the cooling system, if you are still getting bubbling out of the cooling system, I would now look to a head gasket problem. Not sure the extent of the damage from the accident but this seems to be a gasket problem.
Dec 31, 2006 at 10:41 AM
Suggested Repair
With the engine warm and running, slowly open a cooling-system bleeder and fully purge air. If bubbling continues after bleeding, inspect for a head gasket problem possibly related to crash damage.
Conversation Summary
A 1994 Honda Civic began bubbling coolant, steaming from the reservoir, and overheating on the highway after a front-end crash and radiator replacement. Shops suggested a water pump or trapped air, a fan, relay, or fuse. The expert advised bleeding all air from the warm, running cooling system and checking for a head gasket problem if bubbling continues.
