2000 Honda Civic Overheats While Driving
Let me know what you find on those questions.
Do you get any bubbling in the radiator?
Heater core
Hoses
Water pump
Cooling Fan
Radiator
Thermostat
Temp Sensor
Coolant
That is pretty much it and you have replaced all but the Heater Core, fan and hoses with brand new items. Correct? So, what about the prospects of a collapsing hose? The system should pull the coolant from the overflow back in to the system but it can't do so if the system is picking up air and not allowing the system to pressurize. Be honest here, any loss of power to the engine? This is really pointing big time to the head and the head gasket.
Suggested Repair
Suspect a leaking head gasket or warped head even without classic exhaust smell or bubbling. Perform a compression or leak-down test and a combustion-gas test of the coolant. Also inspect hoses for collapse and confirm the system can pressurize and draw coolant back from the overflow.
Conversation Summary
A 2000 Honda Civic 1.6L overheats and loses cabin heat only while moving, then returns to normal. Radiator coolant drops into a full overflow tank and does not siphon back, despite a new thermostat, water pump, radiator, cap, and air purge. Idle testing is normal, plugs look clean, and there is no sweet exhaust smell or radiator bubbling. The expert says early coolant loss into the engine can be hard to detect and points strongly to a head gasket or warped head, while also suggesting collapsing hoses and system pressure checks.
