Honda blower fan problem
TOMMYTAM
My 98 honda civic recently has a blower fan problem, the fan doesnt come on at 1 and 2 setting but it works fine on 3 and 4. I have checked the fan switch, it seems to be working fine Does the civic has two blower fans? Does anyone has the information on that?
Thanks,
-Tommy
Jul 29, 2006 at 5:26 AM
MIKEYBDMAN
  • 623 POSTS
Sounds like you have a blower motor resistor that has gone bad. Basically the fan 4, or high postion bypasses the resistors, and gets full power. In position 3, current goes thru 1 resistor, and in 2 it goes thru 2, and in 1 it goes thru all three. This slows the speed of the fan. A break in the second resistor will kill power in the 1 and 2 speed postions, but allow 3 and 4 to still be powered. Replace the resistor pack and it will be fixed.
This resistor is located on the right side of the airconditioning ducting under your dash. It is below the blower itself mounted right beside the recirculation control motor. If you remove your glove box, you might have a straight shot at replacing it. Remember when you tighten the screws, that this part is made of plastic, and do not over torque the screws. You can damage the new part and still have problems. They mount the resistor pack in the ducting to keep the heat down while power is going thru them at different speeds.
Good luck, and this should be an easy fix for you to do.
Jul 29, 2006 at 9:28 AM
