1999 Honda Civic Blower Speeds 3 and 4 Only
ALLY990
my heater blower on my 1999 honda civic is only working on speeds 3 and 4. Is it possible that the switch is faulty or is there a resistor that could be burnt out?
If the resistor needs replaced where about in the car is it located
Mar 10, 2006 at 12:34 AM
FISHERMAN
  • 937 POSTS
check for burn out switch, sometimes the contacts are faulty and the heat "melts" the plastic housing (inside the switch) and its hard to detect.
Mar 10, 2006 at 7:29 AM
Suggested Repair
Inspect the heater blower switch for burnt or faulty contacts and heat-damaged plastic housing inside the switch, which can be hard to see.
Conversation Summary
The owner of a 1999 Honda Civic says the heater blower works only on speeds 3 and 4 and asks whether the switch or a burnt resistor is at fault, and where the resistor is located. The expert advises checking the switch for burnout, faulty contacts, and melted plastic housing inside the switch.
