1995 Honda Civic No Heat
GREY1995
  • 1995 HONDA CIVIC
  • 4 CYL
  • 140,000 MILES
Bought this for my son this fall. I have replaced the thermostat and radiator. Felt that radiator my be plugged with sealant. Blower works but blows cool air. Flushed heater hoses in both directions. The upper radiator hose (attached to block) gets hot the lower hose (attached to thermostat) is cold. Inlet hose to heater(from block) warm to hot. Outlet hose form heater(to back side of thermostat housing) cool to warm. Am I not getting proper circulation.
Friday, January 23rd, 2009 AT 6:16 AM
KHLOW2008
  • 41,814 POSTS
Hi grey1995,
Thank you for the donation.
Seems the heater hoses are not circulating as well as they should be. Did you check if the heater control valve is opening fully and its linkage adjustments?
Friday, January 23rd, 2009 AT 9:53 AM
GREY1995
Where can I find the heater control valve and how to make adjustments? I have a Alldata subscription. For the vehicle but don't see it.
Friday, January 23rd, 2009 AT 10:18 AM
KHLOW2008
  • 41,814 POSTS
The heater control valve is located near the firewall and attached to the heater core inlet hose.
There is a linkage cable that opens and closes the valve. It can be adjusted.
Friday, January 23rd, 2009 AT 10:26 AM
