2001 Honda Civic Air conditioning
2001 HONDA CIVIC
RAYSUN80
Hi, I recently bought a 2001 honda civic, but when I saw the car, the air was not cold even though I switched on the ac. I checked with a local dealer near my home, he told that it could be the freon is less and he charged it. But even after that it was not cold. Then he checked a switch and when he tried grounding the switch to battery the compressor started working and very cold air started blowing. As a temporary fix, he told that we can put a ground wire. But the problem with doing that is that the compressor is on all the time, whether I switch on/off the AC switch on the dash/control panel or not, the compressor is on and cold air blows. I am not sure if any of the pressure switch is having problem or any wire connectivity issue. Any help/direction you can provide will be of great help. I also want to know if this will be a easy/cheap thing to fix or an expensive one.
Apr 19, 2006 at 9:49 AM
LOSONE
  • 1,616 POSTS
What sw did he jump, the low pressure sw?. he isn't much of a mechanic to make that kind of fix ot will ruin the compressor as it is supposed to cycle.. If that is the sw buy one and install it
@000 vehilces do not use freon. The use R-134A Let me know.
Apr 19, 2006 at 11:03 AM
RAYSUN80
thanks for the prompt responce losone. He mentioned that the high preasure switch is not working. Not sure if it is the low preasure or high preasure. If I have to change these switch how much will they cost and how difficult is it to put the new one in. As of now I have just disconnedted the wire that he grounded. So the compresser is not on all the time now. But the AC does not work now.
Apr 19, 2006 at 1:18 PM
LOSONE
  • 1,616 POSTS
It's about a $15.00 switch that just screws off a nipple, kind of like a valve stem cap. No loss of refrigerant. Good Luck
Apr 20, 2006 at 12:15 AM
RAYSUN80
Thanks losone, I spoke to the dealer from where I bought the car. HE asked me to bring the car in a weeks time and he will check it. I hope leaving the AC without working for a week is fine, and will not cause any damage.
I will let you know on what I find out once I take the car to his place.
Thanks.
Apr 20, 2006 at 6:44 AM
LOSONE
  • 1,616 POSTS
No damage unless the A/C compressor runs all the time. You can run it for a few hours and it won't hurt but not all the time.
Apr 20, 2006 at 8:21 AM
