honda acceleration and startup problem
LUKE1271
I have a 1991 Honda Civic 1.5
I was going down the highway at about 50 and tried to accelerate to 65. When I push the accelerator the engine starts to accelerate but then cuts out if the pedal is pressed too hard. I can usually let off and then press it very slowly and i will eventually make it to the speed that i need. The check engine light is on all the time. And now to top it off I can't get it to start. the ignition will turn over but when it starts to fire it somehow gives up and dies. Then i get a very acrid gasoline smelling grey smoke from the exhaust. It sounds like an injector or fuel filter problem to me. Or some other form of clog in the fuel system.
I tried to jump the switch under the dashboard and get a code, there was no sound and no flashing lights.
Can you offer me any advice or assistance at all?
-Luke
Nov 16, 2006 at 7:42 AM
BRUCE HUNT
  • 3,754 POSTS
Two things that are key to an engine. Gas (which it appears you are getting) and spark. Check for spark at the plugs, a good blue spark.
Nov 16, 2006 at 12:13 PM
LUKE1271
here is a follow up question for you.
can a fuel clog cause my distributor to go bad?
Nov 17, 2006 at 2:37 AM
BRUCE HUNT
  • 3,754 POSTS
I don't see how. No...
Nov 17, 2006 at 3:03 AM
LUKE1271
ok how do i check the plugs for spark?
Nov 17, 2006 at 4:24 AM
BRUCE HUNT
  • 3,754 POSTS
Pull out one plug and insert it back in to the wire and hold the tip of the plug to ground or metal on the engine. Have a partner crank the car and watch the spark. Should have a blue spark. I think you will find spark but I would next check to see if the timing of the spart is close. Do yourself a favor and find the jumper again to read the codes. The check engine light should flash. The key should be in the start position during this.
Nov 17, 2006 at 10:06 AM
