1994 Honda Civic Dies While Driving
BEATSNONSTOP
my 1994 honda civic suddenly stopped while I was driving aroung It will not bump start, jump start, or turn on normally, very strange, in the middle of the intersection the power just died out.
Jul 27, 2006 at 6:44 AM
BRUCE HUNT
  • 3,754 POSTS
I would look to the EFI relay. It is a box in the car under the driver side of the dash. Did you get any "Check engine light". I would suspect that you did and I would provide the code. The car could have suffered a sensor problem like the crankshaft position sensor.
Jul 31, 2006 at 9:14 AM
BEATSNONSTOP
No check engine light was on, which was disappointing because, at least I could trace it that way. The car was running okay, for having 300,000 miles on it, I have been keeping up on the maitenance. the only problem I was having was a occasional backfire/misfire...during the past week. Now after I checked the plugs and wires, I found some of the plugs were semi damp at the top where the wires connect>>>? Any ideas..? I appreciate your time and opinion../
Aug 1, 2006 at 6:08 PM
Suggested Repair
Inspect the EFI relay under the driver side of the dash and consider a crankshaft position sensor fault. Also dry and inspect the spark plug tops and wire connections, since some plugs were damp and the car had recent misfire or backfire.
Conversation Summary
A 1994 Honda Civic with about 300,000 miles suddenly lost power while driving and would not bump start, jump start, or restart. There was no check engine light. The owner reported occasional backfire or misfire the prior week and found some spark plugs damp where the wires connect. The expert suggested checking the EFI relay under the driver-side dash and a possible crankshaft position sensor problem.
