1997 Honda Civic Grinding Noise
FUNNYBR87
i have a 1997 Honda Civic EX with over 160,000 miles to its 4 cylinder 1.6 engine and manual transmission. recently my car suffered a damage to the front driver side. After i tried to drive my car from a dead stop it started to make a grinding sound. It only makes this noise when i let go of the clutch and accelerate. It doesnt make the sound when i start the car or when i accelerate with the clutch pressed in. I replaced my axle thinking that was the problem, but it didnt fix anything. what can it be?
Jul 11, 2007 at 1:39 AM
BRUCE HUNT
  • 3,754 POSTS
Given the age of the vehicle and the possible impact I would look at the heat shields on the exhaust system. Look for one that is loose. Any movement and I would find a way to tighten it or secure it.
Jul 18, 2007 at 4:46 AM
Suggested Repair
Inspect the exhaust heat shields for looseness after the front impact, and tighten or secure any shield that can move.
Conversation Summary
A 1997 Honda Civic with a manual transmission developed a grinding noise after front driver-side damage. The noise occurs only when the clutch is released and the car accelerates, not at startup or with the clutch pressed. Replacing the axle did not help. The expert suggested checking the exhaust heat shields for a loose shield and securing it.
